LED Blinker Erfahrungswerte
schaltung
und jetzt mal eine ordentliche schaltung (gemacht mit Eagle)
[English]
The bridge rectifier makes sure that the wires can be connected either way round.
To the right of the bridge rectifier, an island of clean power is created in a sea of dirty power lines. The P6K transzorb will cut off any voltages over 15 Volts. It is lightning fast and can tolerate peak currents of 200 A.
The capacitors create a reasonably stable DC power.
Then follow n banks of LED's, each with its own current source. I drew 7 banks, but depending on the brightness of the LED's 3 may be enough as well. Some tests will be nice.
Each LED bank uses its own LM317 current source, programmed to 1250/56 = 22 mA. A safe value. The sum of the voltages of the LED's should not exceed 8 Volt.
If m banks blow out, the other n - m will keep working at their own preset currents.
When going for 100 cd of light, the board will cost around 10 euro. On a similar board as this one I would give 5 years of warranty. It's almost indestructable.
[/English]
Vielleicht werde ich einige dutzende Platine fertigen lassen in China. Eine solche module duerfte ausreichend sein fuer verwendung im Blinkeranlage aber auch in Nummerschild beleuchtung und brems licht. Und fuer das Givi Topkoffer auf deine Dicke.. 😱
Also ich habe das Elektronische Relais von loui für 12 Euronen und´ne 1/2 Std Arbeit
investiert und funktionuckelt astrein.
