Alt 04.11.2007, 09:57   #1
pike
Standard Oversize pistons-kolben
Hello! My name is Grega Mlakar and I,m from Slovenia. Last year I have bought GPZ900r 1984 and I,m planning to completely rebuild him in original condition. But I have some problems with spare parts since here in Slovenia are not much GPZ owners. Now I,m looking for oversize pistons since mine cylinders has up to 0,04mm gap between cylinder and pistons. Could any one be so kind and please tell me where I could by a complete kit of four oversize pistons. I,m having some problems since I don’t speak German language. Thank you!
Geändert von Patrick (04.11.2007 um 12:44 Uhr)
Alt 04.11.2007, 12:47   #2
http://www.vwmt.de for original pistons from Kawasaki with oversize from 0,25, 0,5, 0,75 and 1mm or maybe 970ccm³ Pistons from Wiseco http://www.gw-racing-parts.de
Alt 04.11.2007, 16:48   #3
pike
Thank you Patrick! I,m going to by original Kawasaki oversize pistons I hope that this company sends goods to Slovenija.
Alt 04.11.2007, 16:51   #4
I think so...
Write a mail to Volker (Volker Wildung - vwmt.de) and ask him...
Alt 04.11.2007, 23:45   #5
pike
Thank you! I have just sent him an e-mail and I,m waiting for replay.
I have a problem with con rod small end bearing. There is some scoring, about half way trough. It is deep enough, that the piston pin has some up and down play, when i try to twist it or move it up and down, holding just one end. Other con rods are fine, piston pin fits snugly, no noticable play.
The problem is, that the stock, original con rod small end bearing has no bushing, just bare metal. My question is, is it a must to replace a whole con rod, or is there a way to fix it or perhaps live it alone?
Hope it makes sense and thanks for the replay.
Alt 05.11.2007, 01:39   #6
Hello Grega,
if you get any problems to order the spareparts you need by Volker, please be so kind and contact me via PN. I'll support you.
In German thats written " Private Nachricht" and you can find it in the right corner on the Top.
Have a good time
BTW: Das Forum lässt sich bei der Anmeldung auch englisch anzeigen....
Alt 05.11.2007, 07:39   #7
pike
Ich habe Nachricht das aber die deutsche schlechte Sprache zu sprechen sehr
Bremse hinten von 1-Kolben auf 2-Kolben-Bremse GPZMK UT -- Fahrwerk, Reifen, Räder 4 28.06.2021 16:15
Tokico 6-Kolben oder Nissin 4-Kolben?? Was denn nun Nordmann UT -- Fahrwerk, Reifen, Räder 41 31.12.2016 02:22
1 Kolben tiefer winkbuul PD -- Motor 18 13.06.2008 20:19
Größere Kolben Hector UT -- Motor, Vergaser und Kühlsystem 4 22.09.2007 00:20
Alle Zeitangaben in WEZ +2. Es ist jetzt 18:06 Uhr.
