Archiv verlassen und diese Seite im Standarddesign anzeigen : Oversize pistons-kolben
pike
04.11.2007, 08:57
Hello! My name is Grega Mlakar and I,m from Slovenia. Last year I have bought GPZ900r 1984 and I,m planning to completely rebuild him in original condition. But I have some problems with spare parts since here in Slovenia are not much GPZ owners. Now I,m looking for oversize pistons since mine cylinders has up to 0,04mm gap between cylinder and pistons. Could any one be so kind and please tell me where I could by a complete kit of four oversize pistons. I,m having some problems since I don’t speak German language. Thank you!
04.11.2007, 11:47
http://www.vwmt.de for original pistons from Kawasaki with oversize from 0,25, 0,5, 0,75 and 1mm or maybe 970ccm³ Pistons from Wiseco http://www.gw-racing-parts.de
pike
04.11.2007, 15:48
Thank you Patrick! I,m going to by original Kawasaki oversize pistons I hope that this company sends goods to Slovenija.
04.11.2007, 15:51
I think so...
Write a mail to Volker (Volker Wildung - vwmt.de) and ask him...
pike
04.11.2007, 22:45
Thank you! I have just sent him an e-mail and I,m waiting for replay.
I have a problem with con rod small end bearing. There is some scoring, about half way trough. It is deep enough, that the piston pin has some up and down play, when i try to twist it or move it up and down, holding just one end. Other con rods are fine, piston pin fits snugly, no noticable play.
The problem is, that the stock, original con rod small end bearing has no bushing, just bare metal. My question is, is it a must to replace a whole con rod, or is there a way to fix it or perhaps live it alone?
Hope it makes sense and thanks for the replay.
05.11.2007, 00:39
Hello Grega,
if you get any problems to order the spareparts you need by Volker, please be so kind and contact me via PN. I'll support you.
In German thats written " Private Nachricht" and you can find it in the right corner on the Top.
Have a good time
BTW: Das Forum lässt sich bei der Anmeldung auch englisch anzeigen....
pike
05.11.2007, 06:39
Ich habe Nachricht das aber die deutsche schlechte Sprache zu sprechen sehr
